The Developer ribbon contains tools for automation and customization.
View new features for Altair HyperWorks 2024.1.
The Task Manager allows you to organize Python scripts into individual tasks and package them into a single process that you can easily implement. The tasks, their GUI, and the process structure are all defined via an XML file.
Create and edit process and task XML files.
