*CONTACT_TIED
LS-DYNA Input Interface KeywordDefines tied contact between entities.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *CONTACT_TIED_OPTION_{OPTION3} | |||||||
If OPTION3 = ID, insert the following line.
| inter_ID | Title | ||||||
| SSID | MSID | SSTYP | MSTYP | ||||
| Blank line | |||||||
| SST | MST | SFST | SFMT | ||||
Definition
| OPTION |
| OPTION3 |
| inter_ID | Contact ID. (Integer) |
| TITLE | Contact title (only OPTION3 =
ID is defined). (Character) |
| SSID | Secondary nodal set. (Integer) |
| MSID | Main surface set. (Integer) |
| SSTYP | Input secondary set type.
(Integer) |
| MSTYP | Input main set type.
(Integer) |
| SST | Secondary maximum gap value. (Real) |
| MST | Main maximum gap value. (Real) |
| SFTS | Secondary contact gap scale. (Real) |
| SFMT | Main contact gap scale. (Real) |
- This keyword maps to /INTER/TYPE2 with Spotflag = 28 or /INTER/TYPE10.
