*DATABASE
LS-DYNA Input Interface KeywordDefines the output frequency for time history data.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *DATABASE_{OPTION} | |||||||
| DT | |||||||
Definition
| OPTION | Time history output type.
| DT | Time frequency for writing time history
output. (Real) |
- This keyword maps to /TFILE/4. The minimum time interval from all the *DATABASE_{OPTION} defined is used.
- The card controls only the frequency of the output. An additional card may need to be defined to specify which objects will be output. For example, number of nodes, elements, the definition of section force, and so forth.
