/FAIL/RTCL
Block Format Keyword The RTCL (Rice-Tracey–Cockroft–Latham) criterion is a stress triaxiality-based failure model especially adapted to ductile failure.
The theory is based on voiding growth modeling. This failure model can be used for shell and solid elements.
/FAIL/RTCL/mat_ID/unit_ID
EPScal Inst n
Optional line
fail_ID
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit identifier.
EPScal Calibrated simple tension failure strain ε c a l MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aaS baaSqaaiaadogacaWGHbGaamiBaaqabaaaaa@3A89@ (for a reference mesh size of L e MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamitamaaBa aaleaacaWGLbaabeaaaaa@37DE@ if the regularization is activated for shells).
(Real)
Inst Flag to activate damage regularization for shells.
= 0
Default value.
= 1
Necking instability regularization is not activated.
= 2 (Default)
Necking instability regularization is activated.
(Integer)
n Hardening exponent for shell damage regularization.
(Real)
fail_ID (Optional) Failure criteria identifier.
Example (Aluminum)
#RADIOSS STARTER
/UNIT/1
unit for mat and failure
#              MUNIT               LUNIT               TUNIT
                  Mg                  mm                   s
#-  1. MATERIALS:
/MAT/PLAS_JOHNS/1/1
Aluminum
#              RHO_I
              2.7E-9                   0
#                  E                  Nu     Iflag
               70000                  .3         0
#                  a                   b                   n           EPS_p_max            SIG_max0
                  90                 200                  .3                   0                   0
#                  c           EPS_DOT_0       ICC   Fsmooth               F_cut               Chard
                   0                   0         0         0                   0                   0
#                  m              T_melt              rhoC_p                 T_r
                   0                   0                   0                   0
/FAIL/RTCL/1/1
#             EPScal      Inst                   n
                  .2         0                 .67
#  fail_ID
         1
#enddata
  1. The factor is computed according to stress triaxiality as:
    D= 1 ε cr f ∫ 0 ∞ f RTCL (η)d ε p MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraiabg2 da9maalaaabaGaaGymaaqaaiabew7aLnaaDaaaleaacaWGJbGaamOC aaqaaiaadAgaaaaaaOWaa8qCaeaacaWGMbWaaSbaaSqaaiaadkfaca WGubGaam4qaiaadYeaaeqaaOGaaiikaiabeE7aOjaacMcacaqGKbGa eqyTdu2aaSbaaSqaaiaadchaaeqaaaqaaiaaicdaaeaacqGHEisPa0 Gaey4kIipaaaa@4CE0@
    Where,
    η
    Stress triaxiality defined as σ m σ V M MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaSaaaeaacq aHdpWCdaWgaaWcbaGaamyBaaqabaaakeaacqaHdpWCdaWgaaWcbaGa amOvaiaad2eaaeqaaaaaaaa@3C8E@
    σ m MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aaS baaSqaaiaad2gaaeqaaaaa@38D7@
    Mean stress
    σ V M MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aaS baaSqaaiaadAfacaWGnbaabeaaaaa@3992@
    von Mises equivalent stress
    ε p
    Cumulated plastic strain.
    ε cr f MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aa0 baaSqaaiaadogacaWGYbaabaGaamOzaaaaaaa@3A95@
    Plastic strain at failure in simple tension.
    f RTCL MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOzamaaBa aaleaacaWGsbGaamivaiaadoeacaWGmbaabeaaaaa@3A57@
    A factor whose computation is defined below.
  2. The factor is computed according to stress triaxiality as:
    f RTCL ={ 0 if η<− 1 3 2 1+η 12−27 η 2 3η+ 12−27 η 2 if − 1 3 ≤η< 1 3 e − 1 2 e 3 2 η if η≥ 1 3 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOzamaaBa aaleaacaWGsbGaamivaiaadoeacaWGmbaabeaakiabg2da9maaceaa baqbaeqabmWaaaqaaiaaicdaaeaacaqGPbGaaeOzaaqaaiabeE7aOj abgYda8iabgkHiTmaaliaabaGaaGymaaqaaiaaiodaaaaabaGaaGOm amaalaaabaGaaGymaiabgUcaRiabeE7aOnaakaaabaGaaGymaiaaik dacqGHsislcaaIYaGaaG4naiabeE7aOnaaCaaaleqabaGaaGOmaaaa aeqaaaGcbaGaaG4maiabeE7aOjabgUcaRmaakaaabaGaaGymaiaaik dacqGHsislcaaIYaGaaG4naiabeE7aOnaaCaaaleqabaGaaGOmaaaa aeqaaaaaaOqaaiaabMgacaqGMbaabaGaeyOeI0YaaSGaaeaacaaIXa aabaGaaG4maaaacqGHKjYOcqaH3oaAcqGH8aapdaWccaqaaiaaigda aeaacaaIZaaaaaqaaiaadwgadaahaaWcbeqaaiabgkHiTmaalaaaba GaaGymaaqaaiaaikdaaaaaaOGaamyzamaaCaaaleqabaWaaSaaaeaa caaIZaaabaGaaGOmaaaacqaH3oaAaaaakeaacaqGPbGaaeOzaaqaai abeE7aOjabgwMiZoaaliaabaGaaGymaaqaaiaaiodaaaaaaaGaay5E aaaaaa@71C5@
  3. The plastic strain at failure ε cr f = ε cal MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aa0 baaSqaaiaadogacaWGYbaabaGaamOzaaaakiabg2da9iabew7aLnaa BaaaleaacaWGJbGaamyyaiaadYgaaeqaaaaa@4037@ for solid elements. However, two cases can be encountered for shell elements:
    • If Inst=1 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysaiaad6 gacaWGZbGaamiDaiabg2da9iaaigdaaaa@3B6A@ : ε cr f = ε cal MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aa0 baaSqaaiaadogacaWGYbaabaGaamOzaaaakiabg2da9iabew7aLnaa BaaaleaacaWGJbGaamyyaiaadYgaaeqaaaaa@4037@
    • If I n s t = 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysaiaad6 gacaWGZbGaamiDaiabg2da9iaaigdaaaa@3B6A@ : ε c r f = n + ( ε c a l − n ) t e L e MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aa0 baaSqaaiaadogacaWGYbaabaGaamOzaaaakiabg2da9iaad6gacqGH RaWkcaGGOaGaeqyTdu2aaSbaaSqaaiaadogacaWGHbGaamiBaaqaba GccqGHsislcaWGUbGaaiykamaalaaabaGaamiDamaaBaaaleaacaWG LbaabeaaaOqaaiaadYeadaWgaaWcbaGaamyzaaqabaaaaaaa@495F@
      Where,
      n MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqipu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOBaaaa@36C9@
      Hardening exponent (assuming a power type hardening: A + B ε p n MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqaiabgU caRiaadkeacqaH1oqzdaqhaaWcbaGaamiCaaqaaiaad6gaaaaaaa@3C21@ )
      t e MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiDamaaBa aaleaacaWGLbaabeaaaaa@3806@
      Shell initial thickness
      L e MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiDamaaBa aaleaacaWGLbaabeaaaaa@3806@
      Square root of the shell area.
      This last formula allows necking instability for shells to be considered and to regularize the results.
      Note: The calibrated value ε c a l MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aaS baaSqaaiaadogacaWGHbGaamiBaaqabaaaaa@3A89@ is encountered when t e = L e MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiDamaaBa aaleaacaWGLbaabeaakiabg2da9iaadYeadaWgaaWcbaGaamyzaaqa baaaaa@3AFD@ .
  4. Damage can be post-processed in the animation files using the output request DAMA. For shell elements, when an integration point reaches D=1, the integration points stress tensor is set to zero. The element fails and is deleted when the ratio of through thickness failed integration points equals P_thickfail defined in the shell properties. In solid elements, the element is deleted when any integration point reaches D=1.
  5. The fail_ID is used for the failure initialization in the element using the keyword /INISHE/FAIL, /INISH3/FAIL or /INIBRI/FAIL. These values can be written in the .sta file with /STATE/SHELL/FAIL or /STATE/BRICK/FAIL options.
