/GRTRIA/PROP
Block Format Keyword Builds a group of triangles (/TRIA) which are based on given property identifiers.
Enter selected items numbers (any number may be input, 10 per Line)
| /GRTRIA/PROP/grtria_ID/unit_ID | |||||||||
| grtria_title | |||||||||
| item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
| grtria_ID | Group
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| grtria_title | Group title (Character, maximum 100 characters) |
| item_ID1, item_ID2,..., item_IDn | List of property
identifiers (Integer) |
- The 2D solid triangle groups cannot contain 2D solid quadrangles (use /GRQUAD instead).
- If item_ID is a negative number, the item number is deleted from the group.
