#include
Block Format Keyword Points to an include file in the Starter Input (Runname_0000.rad) file.
#include filename
Definition
| filename | Filename and path of the
include file in the Runname_0000.rad input
deck. (Character) |
- The include filename must not contain blank spaces.
- The include file may contain one or more blocks.
- The include file may not contain incomplete blocks.
- The first line of the Runname_0000.rad may not be included in an external file.
- In an include file, all lines after the instruction #enddata are ignored.
- Include files may be in any directory, other than the main file.
- When using sublevel include files, absolute paths for include option are recommended.
- Relative paths are allowed; but refer to the working directory.
- Include files must respect the Radioss version declared in the main file.
- Radioss Starter will stop with an error message, if an include file is not found.
- The line including "#include" cannot be greater than 500 characters.
- Any /BEGIN (units and input version information) defined in an #include is ignored; except when the include file is part of a //SUBMODEL.
