/INIMAP1D
Block Format Keyword Map 1D velocities and thermodynamic values into 2D or 3D space using spherical, cylindrical, or planar mapping methods. The mapped results are used with /ALE/EULER materials.
/INIMAP1D/form/inimap1d_ID
inimap1d_title
type
node_ID1 node_ID2
grbric_ID grquad_ID grtria_ID
fct_IDv Fscalev
fct_IDvf1 fct_IDrho1 Fscalerho1 fct_IDp_e1 Fscalep_e1
etc etc etc etc etc
fct_IDvfN fct_IDrhoN FscalerhoN fct_IDp_eN Fscalep_eN
Definition
form Initial state formulation.
VE
Mass density, specific internal energy and velocity are provided.
VP
Mass density, pressure and velocity are provided.
inimap1d_ID Inimap1d block identifier.
(Integer, maximum 10 digits)
inimap1d_title Inimap1d block title.
type Initial mapping type.
1
Planar mapping
2
Cylindrical mapping
3
Spherical mapping
(Integer)
node_ID1 Node 1 identifier.
node_ID2 Node 2 identifier, only if type=1 or 2.
grbric_ID Brick group on which initialization is performed.
(Integer)
grquad_ID Quad group on which initialization is performed.
(Integer)
grtria_ID Tria group on which initialization is performed.
(Integer)
fct_IDv Function identifier for velocity initialization.
(Integer)
Fscalev Velocity scale factor. 2
(Integer)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
Repeat the following lines for each /MAT/LAW151 or /MAT/LAW51 submaterial 1 through N
fct_IDvf1 Function f v f ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciOzamaaBa aaleaacaWG2bGaamOzaaqabaGcdaqadaqaaiaadshaaiaawIcacaGL Paaaaaa@3B81@ identifier for volume fraction.
= 0
VolumeFraction=Fscal e vf MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvaiaad+ gacaWGSbGaamyDaiaad2gacaWGLbGaamOraiaadkhacaWGHbGaam4y aiaadshacaWGPbGaam4Baiaad6gacqGH9aqpcaWGgbGaam4Caiaado gacaWGHbGaamiBaiaadwgadaWgaaWcbaGaamODaiaadAgaaeqaaaaa @4B6F@
> 0
Volumefraction=Fscal e vf ⋅ f vf ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvaiaad+ gacaWGSbGaamyDaiaad2gacaWGLbGaamOzaiaadkhacaWGHbGaam4y aiaadshacaWGPbGaam4Baiaad6gacqGH9aqpcaWGgbGaam4Caiaado gacaWGHbGaamiBaiaadwgadaWgaaWcbaGaamODaiaadAgaaeqaaOGa eyyXICTaciOzamaaBaaaleaacaWG2bGaamOzaaqabaGcdaqadaqaai aadshaaiaawIcacaGLPaaaaaa@536C@
(Integer)
fct_IDrhoi Function f rho ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciOzamaaBa aaleaacaWGYbGaamiAaiaad+gaaeqaaOWaaeWaaeaacaWG0baacaGL OaGaayzkaaaaaa@3C73@ identifier for density.
= 0
ρ=Fscal e rho MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyWdiNaey ypa0JaamOraiaadohacaWGJbGaamyyaiaadYgacaWGLbWaaSbaaSqa aiaadkhacaWGObGaam4Baaqabaaaaa@412D@
> 0
ρ=Fscal e rho ⋅ f rho ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyWdiNaey ypa0JaamOraiaadohacaWGJbGaamyyaiaadYgacaWGLbWaaSbaaSqa aiaadkhacaWGObGaam4BaaqabaGccqGHflY1ciGGMbWaaSbaaSqaai aadkhacaWGObGaam4BaaqabaGcdaqadaqaaiaadshaaiaawIcacaGL Paaaaaa@49FD@
(Integer)
Fscalerhoi Density scale factor.
(Real)
[ kg m 3 ]
fct_IDp_ei If form=VE, Energy function identifier.
If form=VP, Pressure function identifier.
= 0
P  or  E = F s c a l e p _ e MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuaiaabc cacaqGVbGaaeOCaiaabccacaWGfbGaeyypa0JaamOraiaadohacaWG JbGaamyyaiaadYgacaWGLbWaaSbaaSqaaiaadchacaGGFbGaamyzaa qabaaaaa@4423@
> 0
P  or  E = F s c a l e p _ e ⋅ f p _ e ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuaiaabc cacaqGVbGaaeOCaiaabccacaWGfbGaeyypa0JaamOraiaadohacaWG JbGaamyyaiaadYgacaWGLbWaaSbaaSqaaiaadchacaGGFbGaamyzaa qabaGccqGHflY1ciGGMbWaaSbaaSqaaiaadchacaGGFbGaamyzaaqa baGcdaqadaqaaiaadshaaiaawIcacaGLPaaaaaa@4CDD@
(Integer)
Fscalep_e1 If form=VE, Energy scale factor. 2
If form=VP, Pressure scale factor.
(Real)
[ Pa ] or [ J m 3 ]
/INIMAP1D/VE/1
INIMAP1D for cylindrical mapping
#     Type
         2
# Node_ID1  Node_ID2
         1         4
#grbric_ID grquad_ID grsh3n_ID
         1         0         0
#   func_u
         3
# func_alp  func_rho    func_e
         0         1                             2
/INIMAP1D/VE/2
INIMAP1D for planar mapping
#     Type
         1
# Node_ID1  Node_ID2
      2602    393299
         2         0         0
#   func_u
         3
         0         1                             2
/INIMAP1D2/VE/3
INIMAP1D for spherical mapping
#     Type
         3
# Node_ID1
      5203
         3         0         0
#   func_u
         3
         0         1                             2
/FUNCT/1
RHO
          0.00000000          1.00000000
          0.25000000          1.00000000
          0.50000000          0.25000000
          0.65000000          0.30000000
          0.70000000          0.20000000
          0.80000000          0.20000000
          0.81000000          0.12500000
          1.00000000          0.12500000
/FUNCT/2
EINT
          0.00000000          2.50000000
          0.25000000          2.50000000
          0.50000000          1.40000000
          0.65000000          1.60000000
          0.70000000          2.50000000
          0.80000000          2.50000000
          0.81000000          2.00000000
          1.00000000          2.00000000
/FUNCT/3
VELOCITY
          0.00000000          0.00000000
          0.25000000          0.00000000
          0.50000000          1.16000000
          0.65000000          0.80000000
          0.70000000          0.70000000
          0.80000000          0.60000000
          0.81000000          0.00000000
          1.00000000          0.00000000
#enddata
  1. The option can be used to initialize a 2D or 3D simulation from the results of a 1D simulation potentially obtained from an external solver.
  2. If any inputs for veloctiy, volume fraction, density, energy, or pressure are constant, then the function can be left undefined and the constant values can be entered in the scale factor fields, Fscalev, Fscalerhoi, or Fscalep_e1. If functions are defined, then the default value for the scale factors are 1.0.
  3. Three different initialization types are available depending on the type parameter:
    • type = 1: a planar initialization is performed where the 1D results are mapped onto a plane which is normal to the vector defined from node_ID1 to node_ID2. The abscissa values in an input function are the distance along the plane’s normal vector. The ordinate values from the input function are a constant value for the entire plane at a given distance along the normal. See Figure 1 and Figure 2.
    • type = 2: a cylindrical initialization is performed where the local z cylindrical axis is defined from node_ID1 to node_ID2. The abscissa values in an input function are the radial distance from the local z cylindrical axis. The ordinate values from the input function are a constant value for the entire cylindrical surface at given radial distance. See Figure 3 and Figure 4.
    • type = 3: a spherical initialization is performed, using the origin defined by node_ID1. The abscissa values in an input function are the radial distance from origin. The ordinate values from the input function are a constant value for the entire spherical surface at given radial distance. See Figure 5 and Figure 6.
  4. When form=VE, the model is initialized from density, specific internal energy and velocity. This formulation is available for all mono-material ALE / EULER material laws and with material /MAT/LAW151 (MULTIFLUID) and /MAT/LAW51 (MULTIMAT).
  5. When form=VP, the model is initialized from density, pressure and velocity. This formulation is available for all mono-material ALE / EULER material laws whose equation of state is provided through the /EOS card and with material /MAT/LAW151 and /MAT/LAW51 only if Iform= 12 is used.
  6. If explosive material LAW5 (JWL) is used as submaterial, then mapping will be proceeded considering all explosive was burnt (burn fraction = 1.0). The mapping will be done with detonation products only with a burn fraction = 1.0.
    Figure 1. Mass Density (with input function) Planar Mapping on a 50 x 50 x 50 Cubic Mesh
    Figure 2. Velocity (with input function) Planar Mapping on a 50 x 50 x 50 Cubic Mesh
    Figure 3. Mass Density (with input function) Cylindrical Mapping on a 50 x 50 x 50 Cubic Mesh
    Figure 4. Velocity (with input function) Cylindrical Mapping on a 50 x 50 x 50 Cubic Mesh
    Figure 5. Mass Density (with input function) Spherical Mapping on a 50 x 50 x 50 Cubic Mesh
    Figure 6. Velocity (with input function) Spherical Mapping on a 50 x 50 x 50 Cubic Mesh
