*INITIAL_STRESS_SHELL_{OPTION}
LS-DYNA Input Interface KeywordDefines the reference state for elements belonging to a part, using given nodal coordinates.
For OPTION = <BLANK>
(1) (2) (3) (4) (5) (6) (7) (8)
EID npg nb_integr LARGE
For OPTION = SET
*INITIAL_STRESS_SHELL_SET
SID npg nb_integr LARGE
Stress card for LARGE = 0
T SIGXX SIGYY SIGZZ SIGXY SIGYZ SIGZX EPSP
Stress card for LARGE = 1
T SIGXX SIGYY SIGZZ SIGYZ
SIGZX SIGZX EPSP
Definition
OPTION
<BLANK>
Define initial state for shell element.
SET
Define initial state for all element in the defined set of part.
EID 4 or 3 node shell element identifier.
(Integer)
SID Part set identifier.
(Integer)
npg Number of Gauss point in plane.
= 1
Under-integrated element and 3 node shell element.
= 4
Fully-integrated element.
(Integer)
nb_integr Integration point number through the thickness.
(Integer)
LARGE Format size.
= 0
Regular format.
= 1
Large format.
(Integer)
T Through thickness integration point parametric position between -1 and 1.
(Real)
SIGij Stress value in the direction ij.
(Real)
[ Pa ]
EPSP Plastic strain.
  1. This keyword maps to /INISHE/STRS_F/GLOB or /INISH3/STRS_F/GLOB.
  2. If npg=4, the Gauss integration points in the plane are stored in the following order:
    ( − 3 3 , − 3 3 ) , ( + 3 3 , − 3 3 ) , ( + 3 3 , + 3 3 ) , ( − 3 3 , + 3 3 ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaeWaaeaacq GHsisldaWcaaqaamaakaaabaGaaG4maaWcbeaaaOqaaiaaiodaaaGa aiilaiabgkHiTmaalaaabaWaaOaaaeaacaaIZaaaleqaaaGcbaGaaG 4maaaaaiaawIcacaGLPaaacaGGSaWaaeWaaeaacqGHRaWkdaWcaaqa amaakaaabaGaaG4maaWcbeaaaOqaaiaaiodaaaGaaiilaiabgkHiTm aalaaabaWaaOaaaeaacaaIZaaaleqaaaGcbaGaaG4maaaaaiaawIca caGLPaaacaGGSaWaaeWaaeaacqGHRaWkdaWcaaqaamaakaaabaGaaG 4maaWcbeaaaOqaaiaaiodaaaGaaiilaiabgUcaRmaalaaabaWaaOaa aeaacaaIZaaaleqaaaGcbaGaaG4maaaaaiaawIcacaGLPaaacaGGSa WaaeWaaeaacqGHsisldaWcaaqaamaakaaabaGaaG4maaWcbeaaaOqa aiaaiodaaaGaaiilaiabgUcaRmaalaaabaWaaOaaaeaacaaIZaaale qaaaGcbaGaaG4maaaaaiaawIcacaGLPaaaaaa@559F@
  3. One stress card is added for each integration through the thickness and each Gauss points.
