/MAT/LAW13 (RIGID) (Obsolete)
Block Format Keyword This material law is used to model part(s) as rigid bodies.
| /MAT/LAW13/mat_ID/unit_ID or /MAT/RIGID/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| E | v | ||||||||
Definition
| mat_ID | Material
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| mat_title | Material
| Initial
density (Real) |
| E | Young's modulus Used for computing stiffness in interface (Real) |
| v | Poisson's ratio Used for computing stiffness in interface. (Real) |
Example (Rigid)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/LAW13/1/1
rigid material
# RHO_I
.78
# E NU
210000 .3
#ENDDATA
/END
#---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----|Comments
- /MAT/RIGID is not compatible with kinematic condition or with Advanced Mass Scaling (/AMS), but it is compatible with /BCS.
- /MAT/RIGID is not compatible with /PLOAD, /CLOAD, /GRAV, /IMPDISP, /IMPVEL, /IMPACC, /IMPTEMP, /INIVEL and /INITEMP. If loading is used, it is recommended to use /RBODY, instead of /MAT/RIGID.
