Obsolete
Engine Keyword Keywords that are still supported, but no longer maintained (*) are considered obsolete.
- Overtaken by a new and more powerful keyword
- No longer used
- Dismissed
Note: Obsolete keywords will continue to be supported, but they may no
longer be exposed in upcoming versions of the manual. Also, new keyword are
recommended, instead of obsolete keyword.
Below is a list of Obsolete
Engine keywords:
| Obsolete Keywords | As of Version | Replaced with New Keyword |
| /ALE/0 (or /ALE) | v12.0.210 | |
| /ALE/2 | v12.0.210 | /ALE/SPRING |
| /ALE/3 | v12.0.210 | /ALE/ZERO |
| /ALE/4 | v12.0.210 | /ALE/STANDARD |
| /ANIM/KEEPD | v13.0 | |
| /SHVER/V51 | v13.0 | |
| /VEL/ALE | v13.0 | |
| /ALE/DISP | v14.0.220 | /ALE/GRID/DISP |
| /ALE/DONEA | v14.0.220 | /ALE/GRID/DONEA |
| /ALE/SPRING | v14.0.220 | /ALE/GRID/SPRING |
| /ALE/STANDARD | v14.0.220 | /ALE/GRID/STANDARD |
| /ALE/ZERO | v14.0.220 | /ALE/GRID/ZERO |
| /ALESUB | v2018 | |
| /ANIM/CUT/1 | v2018 | |
| /ANIM/CUT/2 | v2018 | |
| /ANIM/CUT/3 | v2018 | |
| /INCMP | v2018 | |
| /UPWIND | v2018 | /ALE/MUSCL |
| /UPWM/SUPG | v2018 | /ALE/SUPG/OFF |
| /UPWM/TG | v2018 | |
| /MADYMO/ON | v2021.2 | |
| /IMPL/DYNA/FSI | 2022.1 | |
| /DT/GLOB/Iflag | 2022.1 | |
| /DT/NODA/CST1 | 2022.3 | |
| /DT/NODA/CST2 | 2022.3 | |
| /IMPL/SBCS/MSGLV | 2024.1 | |
| /IMPL/SBCS/ORDER | 2024.1 | |
| /IMPL/SBCS/OUTCORE | 2024.1 |
