Intersect
Extract curves resulting from the intersection of the sketch plane with selected parts or surfaces.
Create Intersection Curves
On the Sketch ribbon, select the
Intersect tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - On the toolbar, select Parts to choose parts to intersect with the sketch plane, or select Surfaces to choose surfaces to intersect with the sketch plane.
Select part(s) or surface(s) that intersect with the sketch plane to create
intersection curves.
The intersection curves appear as a dotted red line or curve, and can interact with your new sketch.
Note: When a sketch plane is defined on the face of a part (or an
impression on the face of a part), the intersection curves are generated
automatically. You can disable this option in the Preferences under .
