Transform
Translate or rotate sketch entities.
On the Sketch ribbon, select the
Transform tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. -
Select the sketch entities to translate or rotate.
Note: Use box selection to select multiple sketch entities.
Drag the relevant handle to translate/rotate the selected sketch
entities.
Tip: To reposition the tool, double-click the handle or hold down Shift while clicking it.
To temporarily disable snaps, hold down Alt while clicking.
To Do this Note Translate horizontally - Drag the T handle.
- Select the T handle, and then enter the Horizontal distance.
To maintain or break relations between sketch entities after translation/rotation, select
or
.To restore the original position, select
.Translate vertically - Drag the V handle.
- Select the V handle, and then enter the Vertical distance.
Rotate - Drag the curved handle.
- Select the curved handle, and then enter an Angle.
