Run in GUI (Interactive and Graphic) Mode
GUI mode provides access to all editorial, execution, and management features of the Integrated Development Environment (IDE).
Run in GUI Mode on Windows
Run Twin Activate from the Windows Start menu or installation directory.
In Windows, select from the following options:
- From the Start menu, select .
- From the directory where Twin Activate is installed on your system, select the executable file: <installation_directory>\TwinActivate.bat.
- From a command prompt, enter:
<installation_directory>\hwx\bin\win64\runhwx.exe -c "Activate" -v Activate2024.1 -ef Act.env -ex ExecMainAct.exe
Note: You can pass an .scm file as an input argument to
the invoke command:
-f foo.scmRun in GUI Mode on Linux
Run Twin Activate from the Linux terminal.
your system, execute the script
<installation_directory>/scripts/TwinActivate.
Note: You can pass an .scm file as an input argument to the invoke command:
-f foo.scm
