Jump to main content
Altair Feko  2024 Documentation
2024
Index
  1. Home
  2. Examples
    The Feko Example Guide contains a collection of examples that teaches you Feko concepts and essentials.
  3. Waveguide and Microwave Circuits
    Simple examples demonstrating using waveguides and microwave circuits.
  4. S-Parameter Coupling in a Stepped Waveguide Section
    Calculate the transmission and reflection for a stepped waveguide transition from the Ku- to X-band. Use two solver methods, the method of moments (utilising waveguide ports) and the finite element method (utilising FEM modal ports).
  5. S-Parameter Coupling in a Stepped Waveguide Section (FEM)
    Calculate the transmission and reflection through the waveguide with the finite element method. Use FEM modal ports for the source. Modify the model from topics/feko/example_guide/waveguide_microwave_circuits/waveguide_section_mom_intro_feko_t.html.
  • Welcome
  • Release Notes
  • Get Started
  • Examples
    • Antenna Synthesis and Analysis
      Simple examples demonstrating antenna synthesis and analysis.
    • Antenna Placement
      Simple examples demonstrating antenna placement.
    • Radar Cross Section (RCS)
      Simple examples demonstrating radar cross section (RCS) calculations of objects.
    • EMC Analysis and Cable Coupling
      Simple examples demonstrating electromagnetic compatibility (EMC) analysis and cable coupling.
    • Waveguide and Microwave Circuits
      • Microstrip Filter
        Calculate the S-parameters of a simple microstrip notch filter. Use different solvers and compare the results.
      • S-Parameter Coupling in a Stepped Waveguide Section
        • S-Parameter Coupling in a Stepped Waveguide Section (MoM)
          Calculate the transmission and reflection for the waveguide with the method of moments. Use waveguide ports for the sources.
        • S-Parameter Coupling in a Stepped Waveguide Section (FEM)
          • Creating the Model
            Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
          • Defining Calculation Requests
            Define the calculation requests in CADFEKO.
          • Modifying the Auto-Generated Mesh
            Modify the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
          • Running the Feko Solver
            Run the Solver to compute the calculation requests.
        • Viewing the Results
          View and post-process the results in POSTFEKO.
        • Refining the Mesh with AMRFEKO
          Obtain a computationally efficient mesh with AMRFEKO. Start with a coarse mesh and let AMRFEKO automatically refine the mesh.
      • Using a Non-radiating Network to Match a Dipole Antenna
        Match a short dipole for resonance at 1.4 GHz with an LC matching section. The matched network is modelled using a Spice circuit and S-parameters.
      • Subdividing a Model Using Non-Radiating Networks
        Calculate the input impedance of a circularly polarised patch antenna fed through a microstrip branch coupler. Replace the branch coupler with a non-radiating network and compare with a full solution.
      • Microstrip Coupler
        Calculate the S-parameters (coupling) of a four port microstrip coupler. Use the finite difference time domain (FDTD).
    • Bio Electromagnetics
      Simple examples demonstrating phantom and tissue exposure analsysis.
    • Time Domain
      A simple example demonstrating the time analysis of an incident plane wave on an obstacle.
    • Special Solution Methods
      Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO (large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
    • User Interface Tools
      Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
  • Introduction to Feko
  • CADFEKO
  • POSTFEKO
  • EDITFEKO
  • Feko Solution Methods
  • Optimisation in Feko
  • Feko Utilities
  • Description of the Output File of Feko
  • Feko Application Macros
  • Scripts and Application Programming Interface (API)
  • Appendix
Calculate the transmission and reflection through the waveguide with the finite element method. Use FEM modal ports for the source. Modify the model from S-Parameter Coupling in a Stepped Waveguide Section (MoM).
© 2024 Altair Engineering, Inc. All Rights Reserved.
