Defining a POSTFEKO Report Template
Create a POSTFEKO report template when it is required to create consistent reports. The reports are generated from a preconfigured POSTFEKO report template using styling from aMicrosoft PowerPoint or a Microsoft Word template.
On the Reporting tab, in the
Reports group, click the
Define template icon.
Figure 1. The Define report template dialog.
In the Document type
drop-down list, select one of the following:
- MS Word (*.docx *.doc)
- MS PowerPoint (*.pptx)
- In the Template field, specify the Microsoft template to be used for the report generation.
Click Next.
Figure 2. The Define report template dialog.
- In the Image format drop-down list specify the image format.
- In the Export size drop-down list select the export size of the images used in the report.
- In the table specify the POSTFEKO graph or 3D view for each tag used in the Microsoft template.
Click .
Tip: View the report template in the project browser under Report templates.
[Optional] Modify the report template.
Modify template icon.
