Cleanup Utility
The Cleanup Utility is a script for Windows that removes any custom settings that you may have due to the Altair applications installed.
This is for use when a settings file is corrupted and prevents products from
launching. It cleans the default location of Documents and also cleans the locations
pointed to by the following environment variables, if set:
- HM_COMMANDFILE_DIR
- HW_COMMANDFILE_MODE
- HM_MENUSET_DIR
- HM_MENUSET_OVERWRITE
- HM_SETTINGS_DIR
- HW_SETTINGS_DIR
- HW_CONFIG_PATH
The files or directories that are cleaned include:
- hmsettings.tcl
- hmmenu.set
- command.*
- hwsettings.xml
- .altair directory in Temp
- Altair directories in your home
