Register HVPcontrol
Register HVPcontrol registers the HVP ActiveX control for HyperView Player.
Note: You must run Register HVPcontrol as an administrator.
Start Register HVPcontrol in Windows.
- Click .
- Right-click on Register HVPControl 2024 and select Run as administrator.
A message is displayed stating that the registration was successful. -
Manually switch to a previous or newer version of HVP ActiveX control.
