2024
Translate, rotate, and align the model.
View new features for HyperMesh CFD 2024.
Platforms, operating systems, and processors supported by Altair HyperWorks 2024 products, which includes 2024 solver packages.
Explore the user interface.
View controls enable you to control the view and display of your model in the modeling window.
Select and deselect entities to modify with other tools. Selected entities are outlined to indicate their selection state.
Learn about the different types of measurements available for each setup environment.
Translate and rotate selected entities.
Use snap points to help align geometry.
Several tools require you to define a plane or a vector direction to perform a certain function, such as dragging geometry along a vector, spinning it about an axis, or splitting it with a plane. The Plane and Vector tools are used to define and edit planes and directions.
Use the legends to visualize, edit, and delete instances of model setup parameters.
Use the table and the plot area together to create, edit, and visualize input points for varying data sets.
Undo and redo actions.
Default keyboard shortcuts and mouse controls.
Discover HyperMesh CFD functionality with interactive tutorials and community resources.
Solution-centric workflows allow you to traverse through modeling environments using a dedicated UI layer.
Use the Convert tool to convert entire models between data types.
Manage CAD, FE, and 2D parametric sketch geometry.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Prepare your model and run the simulation.
Post-process the simulation results by creating visualizations and measurements.
Automate simulation processes with templates and utility scripts.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
More resources for AcuSolve and ultraFluidX solvers.
