Translate, Rotate, and Position Entities
Use the Move tool to translate, rotate, and position selected entities.
From the Home tools, click the Move tool.
In the external aero setup environment, you can also press M or T.
In the general environment, the default move mode is set to Interactive.
- Optional:
In the general environment, click
on the guide bar to define movement options.
- In the general environment, select an entity type using the guide bar selector.
Select entities to move.
The Move tool is placed the center of selected entities.
Click a graphical manipulator then do one of the following:
- Drag the graphical manipulator to translate or rotate entities in the selected direction(s).
- Enter a precise value in the microdialog and press Enter.
To Do This Translate along an axis Click the X, Y, or Z arrow. Figure 2.
Translate along a plane Click the XY, XZ, or YX plane square. Figure 3.
Translate freely in 3D space Click the origin of the Move tool. Figure 4.
Tip: Use the icons in the microdialog to align the tool to a part or the global axes.Rotate around an axis Click a curved arrow. Figure 5.
Rotate freely Click at the tip of the X, Y, or Z arrow and drag. In the external aero setup environment, an axis line appears and the unresolved rotation is prompted on release.
Figure 6.
Reposition the Move Tool
Reposition the Move tool along an axis, within a plane, or in 3D space to change the center of rotation.
Figure 8.
Enter editing mode in the following ways:
- Hold Shift.
- Double-click one of the graphical manipulators.
The Move tool becomes orange, indicating that it is ready to be repositioned. - Similar to translating and rotating, use the graphical manipulators and microdialogs to reposition the tool.
Let go of Shift or left-click in empty space to exit
editing mode.
The Move tool displays in white.
Microdialog Options
When clicking the Move tool origin:
- Align the Move tool its default orientation and
position:
- Click once to reset its orientation to match the global coordinate system, or local system if one is assigned.
- Click twice to also reset its position to the centroid of your selection, or the local system origin if one is assigned.
- Align the Move tool along an edge or face. If the Move tool is being repositioned (highlighted orange), clicking this button will force the Move tool to be aligned automatically as you drag it around the model.
- Select and assign a local coordinate system to the Move tool. After a new system is assigned, the
Move tool automatically repositions to its
origin.Note: Currently, the Move tool only supports assigning rectangular coordinate systems.
When clicking a translation or rotation arrow:
- Orient the selected direction using the Vector tool.
- Δ
- Use the
buttons to apply an incremental translation or rotation in the selected direction.
Collision Detection
Prevent components from passing through other components.
Position Entities using Position Mode
Position entities by specifying source and target locations.
Figure 11.
- From the guide bar, change the mode from Interactive to Position.
- From the guide bar, click Source and select up to three source locations in the modeling window.
- Select Target and select an equivalent number of target locations in the modeling window.
- Optional:
Click
and select Show preview to preview the updated position.
On the guide bar, complete one of the
following:
- Click
to apply and stay in the tool.
- Click
to apply and close the tool.
- Click
to exit the tool without applying.
- Click
Example: Align Two Solids
Figure 17.
- Set the selector to Solids then pick the cylinder on the left.
Align the tool with the cylinder's face.
Tip: It is also possible to automatically align the tool to the selected part by clicking
in the microdialog. This works well in many cases, but the result depends on the position and geometry of the selected parts; so for complex scenarios, manually repositioning the origin and axes (as shown above) is a more dependable way of aligning the Move tool.
Translate and rotate the cylinder so it aligns with the other.
