Results Import
Use reader options to control the behavior of the code when reading results from disk.
The reader options are separated into three categories: general and two reader specific options. AcuSolve .log files and files created during General Signal Processing (GSP), .gsph5, can be read directly.
Tip: When Always show dialog at
import check box is activated, the reader option dialog will be
presented each time a data set is loaded. To keep all options for subsequent data
loads, deactivate the option.
General
- Default Step to Load
- First, last, or unchanged. Unchanged is relevant when loading multiple datasets that may have asynchronous times.
- Default Display
- Display smooth geometry: Include the calculation of the surface normal for displaying smooth geometry, requires additional computational resources.
AcuSolve Reader
- Variables
- Toggle the different collections of variables on or off.
- Mesh Motion
- Toggle on to show the displaced mesh and which mesh displacement field to use to compute the deformation.
GSP Reader
- Result Type
- Specify the type of result to load when selecting a .gsph5 file: Frequency, Time, Filtered time or All. .gsph5 files are created during the signal processing workflow and may contain one or more domain specific datasets. In the case where both hydrodynamic dB maps and band filtered pressure data are computed, All may be selected to load the derived fields along with the input pressure field.
