2024
Import an existing file to the current session.
Import FE models for supported solver interfaces.
View new features for HyperMesh CFD 2024.
Discover HyperMesh CFD functionality with interactive tutorials and community resources.
Solution-centric workflows allow you to traverse through modeling environments using a dedicated UI layer.
File formats supported.
Create a new file.
Open a file.
Learn about the supported CAD readers and the options available for importing CAD geometry data.
When an external input translator is used to import data, the application creates a file for messages in the directory in which the program was started.
Use reader options to control the behavior of the code when reading results from disk.
Save all of the data in your current session.
Export FE data in your current session.
Record a video or take a snapshot of the screen.
Quickly import and export templates containing full simulation settings, part definitions, or mesh controls.
Use the Convert tool to convert entire models between data types.
Manage CAD, FE, and 2D parametric sketch geometry.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Prepare your model and run the simulation.
Post-process the simulation results by creating visualizations and measurements.
Automate simulation processes with templates and utility scripts.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
More resources for AcuSolve and ultraFluidX solvers.
