Define Edge Mesh Size
Use the Edge tool to define local mesh settings on selected edges.
Select the surfaces on which to apply the mesh
control in the following ways:
- While in the Mesh ribbon, select edge lines, then right-click and select from the context menu.
- From the Mesh ribbon, click the
Edge tool.
Select edge lines.
- In the dialog, enter an average element size.
From the guide bar, execute the command in the following
ways:
- Click
to confirm your selection and remain in the tool.
This allows you to continue creating instances and helps you visualize and edit instances with the legend.
- Click
to confirm your selection and exit the tool.
- Click
