Explore additional post-processing options related to the input result files.
Create your own user defined coordinate systems or select result coordinate systems.
View new features for HyperLife 2024.
Discover HyperLife functionality with interactive tutorials.
Fatigue Analysis is intended for solutions to structures in a large number of loading cycles.
Set up your model for analysis.
Run the model and view results.
Explode the model and create derived load cases.
Use the Sets tool to create, import, and export sets/groups of components (parts), elements, and nodes.
Explore the various result plotting tools for the imported result files.
Annotate model results using Notes and Measures.
The Expression Builder is a graphical user interface which allows user-defined data type expressions to be authored directly within HyperLife.
The User Defined System dialog allows you to define your own coordinate systems and use them for post processing results.
In the Contour, Iso, Tensor, and Vector panels, you can select the result coordinate system to be used to process results.
For shell (or planar) elements, results in any 3D coordinate system can be projected onto the element plane.
