Set User Preferences File
A preferences file is an ASCII file that configures the application or its clients, and specifies default user settings such as the readers, functions, and solver script locations.
A standard preferences file is created in the program installation directory and is executed every time a license is activated. An additional preferences file can be created in your working directory, and can contain personal settings that will either overwrite the standard preferences file or be added to the existing settings in the standard preferences file.
By default, HyperStudy uses the default preferences file
($HST_ALTAIR_HOME/hw/preferences_hst.mvw).
Note: To use the
custom preferences file in batch mode, you need to use the option
–preffile preferences file name.mvw.
For more information, refer to HyperStudy Start Options.
- From the menu bar, select .
- In the Set Preferences File dialog, select your custom preferences file and click Open.
After you have set a user preferences file, you can select a new preferences file or
disable the custom preferences file.
- Select a new custom preferences file by selecting menu bar. from the
- Disable the custom preferences file by selecting menu bar. The Use Preferences File checkbox should be off. from the
Preference File Reading Sequence
The locations and order in which HyperStudy will load preference files.
- Read main installation preference
getenv("ALTAIR_HOME") + "/hw/preferences_hst.mvw
- Read user preference files
getenv("USER_PREFERENCES_HST"
(points directly to a file)getenv("USER_PREFERENCES_HST_DIR")/*.mvw
(all *.mvw files in directory)- Linux:
(Linux) getenv("HOME")/.preferences.mvw
- Linux:
<current working dir>/.preferences.mvw
preferences.mvw
(single file)getenv("HW_SETTINGS_DIR")/HyperGraph/preferences.mvw
- Windows:
C:/Users/<user>/Documents/HyperGraph/preferences.mvw
- Linux:
$HOME/.altair/HyperGraph/preferences.mvw
preferences/*.mvw
(directory)getenv("HW_SETTINGS_DIR")/HyperStudy/preferences/*.mvw
- Windows:
C:/Users/<user>/Documents/HyperStudy/preferences/*.mvw
- Linux:
$HOME/.altair/HyperStudy/preferences/*.mvw
getenv(HW_CONFIG_PATH)
, a list of directories separated by semicolons- In every directory, HyperStudy tries to
read
<dir>/preferences.mvw
read
- Read -preffile commandline argument
- Read registered GUI preference file
- Read study preference file (hstbatch only)
- <studyDir>/_usr/hstudy_pref.mvw
