Register Reports
Register custom reports in HyperStudy by editing the preferences file.
Tip: Add to your list of reports with custom reports. To learn more,
reference Create Reports.
Register Reports by Editing the Preferences File
Register reports in the *BeginRegisterReportGenerators() section of the preferences_study.mvw file.
In the Editor, open the
Tip: You can find the preferences_study.mvw file in the HyperWorks installation directory under <install directory>/hw/prefinc/.
- Search for the syntax *BeginRegisterReportGenerators().
Immediately following the existing
*BeginRegisterReportGenerators() statements, register
further reports using the following syntax:
where:*BeginRegisterReportGenerators(report_name)- report_name
- Full path of the report, including file name and extension.
- Save the preferences_study.mvw file.
Register .data Report in the Preferences File
In this example, a .data report is added to the reports section
file.
*RegisterReportGeneratorFile("C:\v1.py")
*EndRegisterReportGenerators()
