2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Use the Task Manager to load an XML file that defines tasks and their attributes.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Assigns arguments to the hmreslib program.
Call this function to place arguments into categories.
Allows translation of binary files across a platform. This function gives a list of arguments that allows you to tell a program which machine wrote the binary file.
Indicates the argument name at the user-specified index.
Indicates the data type name of the argument at the user-specified index.
Indicates the data type name and appends, in parentheses, the value of layer at the user-specified index.
Indicates if the argument at the user-specified index is selected.
Indicates the type associated with the argument at the user-specified index.
Takes the arguments passed into the program and determines what is selected.
Prints the selected arguments.
Sets an argument as being selected. This function can also be used to change whether an argument is selected or not.
Assigns the function used to parse the arguments.
Assigns the function that prints out what the argument is assigned.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
