2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Use the Task Manager to load an XML file that defines tasks and their attributes.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Calculates principal stresses given triaxial and shear stresses.
Calculates the vonMises stress given triaxial and shear stresses.
Converts a buffer containing floating point information from one machine type to another machine type.
Converts a buffer containing integer information from one machine type to another machine type.
Use to convert a complex number in magnitude/phase format to real/imaginary format. This function modifies the values passed.
Reads a floating-point number from a binary file which opened with HMRES_openinputfile(). It pays attention to the cross platform flags and does a conversion on the number, making it understandable to the machine the program is running on.
Reads a binary integer from a binary file opened with HMRES_openinputfile(). It pays attention to the cross platform flags and does a conversion on the integer, making it understandable to the machine the program is running on.
Reads a 2-byte integer from a binary file opened with HMRES_openinputfile(). It pays attention to the cross-platform flags and does a conversion on the number, making it understandable to the machine on which the program is running.
Use to convert a complex number in real/imaginary format to magnitude/phase format. This function modifies the values passed.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
