2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Gets the list of datatypes in a specific subcase of the current source file.
Gets the list of requests in a specific datatype of the current source file.
Gets the list of subcases in the current source file.
Use the Task Manager to load an XML file that defines tasks and their attributes.
