View new features for version 2024.
The Python API documentation for HyperMesh applications.
Sets an aliasing rule for channel labels.
Clears currently defined aliases.
Gets the current compression level for all data channels.
Gets the current configuration file name.
Gets the last data point index to be translated.
Gets the current input file name.
Gets the list of filters associated with various supported formats.
Gets the current increment between data points to be translated.
Gets the pattern associated with a previously defined alias.
Gets the replacement string associated with a previously defined alias.
Gets the number of currently defined aliases.
Gets the number of parameters required by a math function.
Gets the current output file name.
Gets the current scale factor for all time channels.
Gets the current starting data point index.
Saves the current configuration to a file.
Sets the compression level for all data channels.
Sets the configuration file name.
Sets the last data point index to be translated.
Sets the input file name.
Sets the increment between data points translated.
Sets the output file name.
Sets the starting data point index.
Sets the scale factor for all time channels.
Begins the process of reading from the input file and writing selected channels to the output file.
Use the Task Manager to load an XML file that defines tasks and their attributes.
