hgtrans control SetConfigFile
Sets the configuration file name.
hgtrans control SetConfigFile filename
HyperGraphTrans Tcl Modify
This command sets the configuration file that will be read prior to beginning translation. This file will be parsed as Tcl.
- filename
- Filename must be the path name of a Tcl file.
Context
Cause hgtrans to read everything from a MADYMO file
        called “ANGACC” and save it to
        “ANGACC.abf”.
    Create a file called "config.tcl" with the following lines in it:
hgtrans control SetFile "ANGACC"
hgtrans control SetOutputFile "ANGACC.abf"
hgtrans config SetAllChannelsSelected
Then run hgtrans and enter the following commands:
hgtrans control SetConfigFile "config.tcl"
hgtrans control StartTranslationErrors
An error will be reported during translation if the file is not present or not supported.
Keywords
set compression file
