2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Evaluates the data member to update the new values.
Gets the list of valid enumeration values for this data member.
Gets the code of the last error which occurred.
Gets the evaluated value of the expression assigned to the data member.
Gets the raw expression used to specify the value of the current data member.
Gets the handle of the object to which a reference data member is resolved to.
Gets the type of entity used to resolve this data member.
Determines whether the value of the current data member may or may not be modified.
Determines whether or not a data member is obsolete.
Determines if the value has been modified.
Determines whether or not a reference data member is resolved.
Determines if this data member is for the slave side of a symmetric pair.
Marks a data member as obsolete so that the next evaluation evaluates that data member.
Used to set expressions for a data members.
Tests the evaluation of an expression without re-evaluating the entire model.
Use the Task Manager to load an XML file that defines tasks and their attributes.
