2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Retrieves the coordinates of interface node at the given index.
Retrieves the number of nodes in the flexbody.
Retrieves the coordinates of the node at the given index.
Retrieves the number of interface nodes in the flexbody.
Use the Task Manager to load an XML file that defines tasks and their attributes.
