2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Returns the bar chart color index.
Gets a named meta-data value previously associated with the chart.
Gets the symbol style of the bar chart.
Sets the bar chart color index.
Sets the symbol style of the bar chart.
Use the Task Manager to load an XML file that defines tasks and their attributes.
