2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Gets a handle to a pltIVector interface for the specified curve.
Gets the data group parametric state.
Sets the data group parametric state.
Use the Task Manager to load an XML file that defines tasks and their attributes.
