2022.1 API Programmer's Guide
Panel Removal
The panel API commands will be also deprecated and removed with the v2023 release. They remain supported until then. However, referencing a deprecated panel in these commands will result in a silent failure.
Existing scripts that are using the panel commands will have to be updated and the operations performed on the panels will have to be replaced by context APIs to work with the corresponding contexts.
Below is a list of commands that will be deprecated with the v2023 release.
- hm_callpanel
- hm_callspecialpanel
- hm_callviewpanel
- hm_callvispanel
- hm_pushpanel
- hm_pushpanelitem
- hm_activateitem
- hm_completemenuoperation
- hm_disablecollector
- hm_disableitem
- hm_disablemenudrawing
- hm_disablepopup
- hm_dumppanel
- hm_enableitem
- hm_enablemenudrawing
- hm_enablepopup
- hm_exitpanel
- hm_getcolnumber
- hm_getcurrentmenu
- hm_getinputentry
- hm_getitemnumber
- hm_getitemnumberbytag
- hm_getitemowner
- hm_getitemposition
- hm_getitemtype
- hm_getpanelarea
- hm_getpanelitems
- hm_getpanelposition
- hm_getradiobutton
- hm_gettwoitemtoggle
- hm_initpanel
- hm_listpanels
- hm_panelnamevalid
- hm_registerentitysubtypefilter
- hm_renameitemonpopup
- hm_renamepanelonpage
- hm_resetcollectorfilter
- hm_resetmenu
- hm_setcardprevreviewproc
- hm_setcollector
- hm_setcollectorfilter
- hm_setentitysubtype
- hm_setinputentry
- hm_setinterfacepanelproc
- hm_setitemposition
- hm_setitemvisible
- hm_setlinemeshpanelproc
- hm_setmainpanel
- hm_setpage
- hm_setpanelheight
- hm_setpanelname
- hm_setpanelonpage
- hm_setpanelposition
- hm_setpanelproc
- hm_setpopup
- hm_setradiobutton
- hm_setrigidwallpanelproc
- hm_setstaritem
- hm_setsystempanelproc
- hm_settwoitemtoggle
- hm_togglemenu
- hm_unregisterentitysubtypefilter
The panels and panel API commands continue to be supported in HyperWorks Desktop.
Properties to Comments
The PAM-CRASH keyword CDATA has been mapped from the property entity to the comment entity. Scripts that created or queried the property entity for this keyword must be updated to use the comment entity.
*createentity comments config=401
*setvalue comments id=1 STATUS=1 numberoflines=2
hm_getvalue comments id=1 dataname=numberoflines
Properties to Materialbehaviors
The LS-DYNA *MAT_ADD keywords has been mapped from the property entity to the materialbehavior entity. See the materialbehaviors data names documentation for more details.
Scripts that created or queried the property entity for these keywords must be updated to use the materialbehavior entity.
*createentity materialbehaviors config=101
*setvalue materialbehaviors id=1 STATUS=1 MXPRES=11.5
hm_getvalue materialbehaviors id=1 dataname=MXPRES
Properties to Sets
The Radioss keyword /ADMESH_SET has been mapped from the property entity to the set entity. Scripts the created or queried the property entity for this keyword must be updated to use the set entity.
*createentity sets cardimage=ADMESH_SET
*setvalue sets id=1 STATUS=1 8041=3
hm_getvalue sets id=1 dataname=8041
New Commands
- Axisymmetric Modeling
- Data Names
- General/Core
- Geometry
- HMASCII
- Impact Tool
- Meshing
- Modules/Parts
- Multiple Models
- Post-processing
- Template Commands
- Template Functions
Modified Commands
- Data Names
- features - New definition and values of the invalid data name.
- Feature Recognition
- *detectandcreatefeatures - The mark argument has been replaced with new arguments elem_mark and surf_mark.
- Composites
- *compositeanalysis - Added new optional argument loadcase and added new supported entity type elements.
- *vabs - Added new optional arguments exportvabs, filepath, and createelements.
- Data Names
- attachments - Added new data names holelongdiameter and holeshortdiameter.
- beamsects - Added new data names
dt_field, dt_dataset, and
sketch.
- elastic - Added new config value 4.
- bodies - Added new data name bodyparts.
- comments - Added new config value 401.
- constraints - Added new data names ALPHA1, ALPHA1_FID, ALPHA2, ALPHA3, BETA1, BETA1_FID, BETA2, BETA3, DENS, GAMMA, iflag, INTP, LCDEXP, LCF, LCUPF, LCUPR, mainid, MODEL, MRN, MRS, mtype, NSID, numgrnodes, numnodes, numrbodies, optionalcard, PID1, PID2, PIDVB, R, RN, RN_FID, RS, RS_FID, secondarygrnodids, secondarynodeids, secondaryrbodyids, SROPT, STIFF, STIFF_FID, STIFF_MID, STIFF_Negative, STIFF2, STIFF3, STIFF4, stype, THICK, TITLE, UPFN, UPFS, UPRN, and UPRS.
- designvars
- shape - Added new data names bounds_gset and bounds_direction.
- failures - Added new data names A_Ref, Beta1, Beta2, Biaxf, C_jcook, c1_orthbiquad, c2_orthbiquad, c3_orthbiquad, c4_orthbiquad, c5_orthbiquad, deps0, El_ref, Eta1, Eta2, fct_ID_rate, Inst_start_orthbiquad, Iside, Kres1, Kres2, le_max, Nangle, OUT_FLAG, Pflag, Pscale, rad_grbric_id, Rate_Scale, Shrf, Sig_0, strdef, Tau1, Tau2, and Tdel.
- loads
- constraints - Added new data names for LS-DYNA engineering loads dyna_death, dyna_deathd, dyna_final_geometry_coords, dyna_lcid, and dyna_lcidf.
- forces - Added new data names for composite plate loads thermal_bottom and thermal_top.
- pressures - Added new data names for OptiStruct engineering loads activation_time, contact_interface, entity_select_option, main_orient, main_set, os_g1, os_g2, pressure_threshold, secondary_ent_flag, secondary_orient, and secondary_set.
- membersections - Added new data names autoweld and auto_detect_thin_solids.
- opticontrols - Added new data names almtostr and almtostrtoggle.
- plotcontrols - Added new data names custom_legend and legend.
- points - Added new data name coordinates.
- properties - Added new data names poleforpmlCoordinates, poleforpmlnodeid, and poleforpmltype.
- rbe3 - Added new data names rwghtx, rwghty, rwghtz, twghty, and twghtz.
- seatbelts - Added new unit_system value 2 and new data names seg_wrapcompcount, seg_wrapcomps, and update_adjbelt.
- seasubsystems - Added new config value 1008 and new data names Sea_Acoustic_Spaces, Sea_Sif_Elements, and Space_FreeSurface_Area.
- sections - Added new data name shell_benstif.
- sets - Added new data name segment_display_state.
- structuralproperties - Added new config value 84 and new data names se_aimingtype, se_armlength, se_contactdist, se_contactpoint, se_hangle, se_headcenter, se_moveback, se_normal, se_pivotpoint, se_positioningtype, se_regulation, se_srp, se_vangle, and se_zlevel.
- General/Core
- hm_getgeometrynodes - Added new optional argument query_type.
- hm_getnodegeometry - Added new valid value fegeometry for optional argument geom_type.
- *barrierpositioner - Added support for roof crush load case for LS-DYNA and Radioss. Added new arguments barrierpitchangle, barrierrollangle, and roof_entities. Added new config value 61.
- *nodelistbypath2 - Added new argument search_factor.
- *setoption/hm_getoption - Added new options beam_mesh_vis, g_ce_aspect_ratio_option, g_ce_aspect_ratio_value, g_ce_autocreate_attachments, g_ce_autocreate_parts, g_ce_bl_connection_angle, g_ce_consider_custom_metadata_mappingg_ce_consider_link_for_review, g_ce_considerboltcolinearity, g_ce_consider_custom_metadata_mapping, g_ce_custom_metadata_file_path, g_ce_elem_org_comp_id, g_ce_elem_org_option, g_ce_equia_skew_option, g_ce_equia_skew_value, g_ce_jacobian_option, g_ce_jacobian_value, g_ce_line_vertex_angle, g_ce_linked_connector, g_ce_linked_entity, g_ce_long_weld_length, g_ce_lt_connection_angle, g_ce_realization_connector, g_ce_realization_link, g_ce_se_auto_register, g_ce_se_cleanup_delete, g_ce_se_cleanup_unrealize, g_ce_shell_thickness_off_for_solids, g_ce_short_weld_length, g_ce_subsystem_org_option, g_ce_warpage_option, g_ce_warpage_value, last_simulation_current, and partbrowser_with_components.
- Geometry
- *beams_to_surfaces - Added new optional arguments 1dtosolid, referencepoint, x_breakangle, y_breakangle, smoothcurves, shellsectiondestination, and surfacecreationtype.
- *linesplitatmultiplelines - Added new option cross_trim.
- Meshing
- *createelements1d - Added new optional arguments engineeringconfig and propcardimage.
- *stiffenedpanelmesh - Added new optional arguments BeamEntTypeU, BeamEntTypeV, BeamSecPropIDU, BeamSecPropIDV, LateralName, LongitudinalName, OriginPoint, PanelName, ShellPropID, and XDirPoint.
- *update1delements - Added new optional argument defaultmaterial, propcardimage and sectiontype.
Removed Commands
The following commands/options have been removed and are no longer available for use in scripts:
- Data Names
- plotcontrols - Removed data names tensor_color_by_mode and vector_color_by_mode.
- Geometry
- *beams_to_surfaces - Removed argument usebeamnode.
