Energy Distribution - Study
After plotting the energy contribution curves, perform a Partial sum, Modify energy, or Energy overlay response study.
- Frequency range
- Indicates the available range, based on the frequencies that your energy distribution analysis has performed.
- Type
- The response study type.
- % to exclude
- Optional field that allows you to exclude a percentage of the energy distribution from the total system energy.
- Select contributors to
- Select the energy distribution that you want to exclude or include in
the response study.
- Click
to select the entire list of contributors.
- Click
to deselect your current selections.
- Click
energy distribution for the unselected energy distribution in the list.
- Click
- Show difference curve as
- Shows a difference curve between the original energy distribution analysis response and the Partial sum or the Modified energy energy distribution analysis response curves.
- Display Options
- Use the Display Options dialog to further customize the plot.
- Display
- Displays the response study plot once your selections are complete.
