RBDO
Set up a reliability-based optimization (RBDO) and execution by defining objective of decoupling rigid body modes, creating constraints for rigid body mode frequencies and specifying design space for variables in terms of mount stiffness, locations, and inclinations.
Specify a design space for design variables. It can be set from nominal values or optimized values from a deterministic optimization run.
Define an objective for rigid body mode decoupling criteria.
Create constraints for rigid body mode frequencies and specify system reliability.
Display and compare rigid body mode frequencies and kinetic energy, baseline vs. optimized. Show the review comparison of design variables, optimized vs. baseline. You can save the configuration file with optimized design variables for further studies.
