Use Batch Create Module to create assembly hierarchy and assign ID ranges to the
modules from external .csv files.
It is also possible to assign ID ranges manually. It shows the detailed summary of module
ID ranges in terms of assignment, validity and conflicts.
Right-click a module in the Assembly Browser and select
Batch Create Module to open the dialog.
Assembly Hierarchy Creation and ID Assignment from an External CSV File
Click Import to open the Import modules and id
ranges dialog.
Load a .csv file that has assembly hierarchy and ID assignment
definition.
Select the modules and click OK to
create modules in hierarchy and assign ID ranges.
All of the modules and corresponding ID ranges are populated on the left hand side. Use the
Assign arrow to create the modules and assign ID ranges. You can also unassign the ID range
by clicking the Unassign arrow. Figure 1.
Assignment, Validity and Conflicts Status of Module ID Ranges
The detailed summary of module ID ranges in terms of assignment, validity and conflicts is
shown in the ID Manager with color coding. ID ranges for the modules can be exported in
external .csv files using the Export button. The assigned ID ranges for
modules can be modified/changed using the Edit icon. It is possible to visualize all modules
in an assembly or only child modules with representation files. There are also options to
view Open and Open+ ranges. Figure 2.
