Batch Run Procedure
A sample zip file and sample batch script are provided in this location of the installation:
<installationdir>\hwdesktop\utility\nvh\fin\batch_scripts\ghn_scripts.
The batch script is divided into sections, and you must specify the input parameters required. Each line of the script must end with a semicolon symbol, “;”. The Pack and Go option is also supported.
"installationdir/hwdesktop/hwx/bin/win64/runhwx.exe" -client HyperWorksDesktop -plugin HyperworksNvh -profile HyperworksNvh -l en -b -tcl
"installationdir/hwdesktop/utility/nvh/fin/batch_scripts/ghn_scripts/BatchScript_ExteriorResult.tbc" “directory/Batch_Script_Exteriror_Result.txt"
"installationdir/altair/scripts/hwx" -client HyperWorksDesktop -plugin HyperworksNvh -profile HyperworksNvh -l en -b -tcl
Below are the script file sections:
- GHN Script: Input/Output Section
Section_Type = Input/Output
Project_Directory = /stage/users_name/;
Project_File=test.xml;
Exterior_Result=1;
Interior_Noise=1;
FFTA=1,Probes=1,dBMap=1;
FFTA_Report=Yes,dBMap_Report=Yes;
- GHN Script: Input Result File
Section_Type = Ufx_Result_File
Panel_Name=Front_Driver_Side_Glass;PanelFilename=/stage/user/fdgs.h3d;
Probes_Analysis_Ufx_Result_Filename=/stage/user/probes_1.csv,/stage/user/probes_2.csv or /stage/user/probes;
FFTA_Ufx_Result_Filename=/stage/user/sectioncut_1.h3d,/stage/user/sectioncut_2.h3d;
dBMap_Ufx_Result_Filename=/stage/user/dBMap.h3d,/stage/user/dBMap_2.h3d,Front_Driver_Side_Glass or * or Directory Name;
- GHN Script: Exterior Result Processing
Section_Type = Exterior_Result
# Advanced Option
Flow_Speed=110;Flow_Speed_Ratio=0.6;Mach_Scaling_Factor=2;
- GHN Script: Transfer Function
Section_Type = Transfer_Function;
Vehicle_Type=SUV;
# Acoustic Cabin
Cabin_Volume = 24000;Reverberation_Time=0.06;Analysis_Bandwidth = 1/3 Octave;
# Panel Geometry and Material
Panel_Name=Front_Driver_Glass;Area=10000; Material=Glass; Total_Thickness=2;Laminate_Material=PVB;Lamintate_Thickness=2;
Material_Database =/stage/user/MaterialDataBase.csv;Damping_Database=/stage/user/DampingDataBase.csv;
- GHN Script: Probes Analysis
Section_Type = Probes_Analysis;
# Custom Time Range
Custom_Time=Yes;Time_Range=2-3;
# Element Selection Section
Element ID=E1;Satellite_Probes=Yes;Radius=0.005;Type_of_Output=Individual Response;
# Output Section
Response Type=Frequency
Domain;Scale=dBA;Output_Type=PSD;Plot_Type=Narrowband;Frequency_Range=100,10000;
- GHN: Cutection Section Analysis
Section_Type = FFTA;
# Time Section
# Band and Frequency Range Selection
BandType=Custom;Frequency_Range=950-1050,1950-2050;
Section_Type = dBMap;
# Time Section
- GHN: Signal Processing Parameter
Section_Type = Signal_Processing_Parameter ;
Block_Size=4096;Overlap=50; Time_Windowing=Hanning;
- Section_Type=Acoustic_Transient_Result;
list_of_panel_name= Front_Driver_Side_Glass;
