With the stress being separated into deviatoric and pressure (hydrostatic) stress (Stresses in Solids), it is the deviatoric stress
that is responsible for the plastic deformation of the material. The hydrostatic stress will
either shrink or expand the volume uniformly, that is, with proportional change in shape.
The determination of the deviatoric stress tensor and whether the material will plastically
deform requires a number of steps.
Perform an Elastic Calculation
The deviatoric stress is time integrated from the previous known value using the strain
rate to compute an elastic trial stress:図 1.
Where,
Shear modulus
This relationship is Hooke's Law, where the strain rate is multiplied by time to give
strain.
Compute von Mises Equivalent Stress and Current Yield Stress
Depending on the type of material being modeled, the method by which yielding or failure is
determined will vary. The following explanation relates to an elastoplastic material
(LAW2).
The von Mises equivalent stress relates a three dimensional state of stress back to a
simple case of uniaxial tension where material properties for yield and plasticity are well
known and easily computed.
The von Mises stress, which is strain rate dependent, is calculated using the
equation:図 2.
The flow stress is
calculated from the previous plastic strain:図 3.
For material laws 3, 4, 10, 21, 22, 23 and 36, 式 3 is modified according to the different modeling
of the material curves.
Plasticity Check
The state of the deformation must be checked.図 4.
If this equation is satisfied, the state of stress is elastic. Otherwise, the flow stress
has been exceeded and a plasticity rule must be used (図 1).図 5. Plasticity Check
The plasticity algorithm used is due to Mendelson. 1
Compute Hardening Parameter
The hardening parameter is defined as the slope of the strain-hardening part of the
stress-strain curve:図 6.
This is used to compute the plastic strain at time :図 7.
This plastic strain is time integrated to determine the plastic strain at time :図 8.
The new flow stress is found using:図 9.
Radial Return
There are many possible methods for obtaining from the trial stress. The most popular method involves a
simple projection to the nearest point on the flow surface, which results in the radial
return method.
The radial return calculation is given in 式 9. 図 2 is a graphic representation of radial return.図 10.
図 11. Radial Return
1Mendelson A., Plasticity: Theory and Application, MacMillan Co.,
New York, 1968.
