2024
Discover MotionSolve functionality with interactive tutorials.
View new features for MotionSolve 2024.
MotionSolve® is an integrated solution to analyze, evaluate, and optimize the performance of multibody systems.
Learn how to access and download required model files.
In this tutorial, you will learn how to create a model of a four-bar trunk lid mechanism interactively through the MotionView graphical user interface, perform a kinematic analysis on the model using MotionSolve, and post-process the MotionSolve results in the animation and plot windows.
Learn how to use some features available for post-processing animation results in HyperView, and how to control the display of the simulation results using Entity Attributes.
Learn how to view force and moment vectors from a MotionSolve results file, use the collision detection feature, and use the measure panel to extract information from animation results.
Learn to import MotionSolve results (plot) files for plotting curves, plot multiple curves in one window, plot multiple curves in different windows on one page, and save your work as a session file.
In this tutorial, you will learn how to build a model with sensor elements to capture the state of a body, use the sensor signal to activate some joints and deactivate others, and carry out a sequential simulation.
In this tutorial you will learn how to model a PTCV (point-to-curve) joint.
In this tutorial, you will learn how to model a CVCV (curve-to-curve) joint.
This tutorial will guide you through the new analytical 3-D rigid body contact capabilities in MotionView.
Learn how to create Curve Entities and Curve Graphics, use macros to create them simultaneously, and setup a 2D rigid curve to curve contact.
MotionSolve is a system level, multibody solver that is based on the principles of mechanics.
This manual provides a detailed list and usage information regarding command statements, model statements, functions and the Subroutine Interface available in MotionSolve.
