2024
Discover MotionSolve functionality with interactive tutorials.
View new features for MotionSolve 2024.
MotionSolve® is an integrated solution to analyze, evaluate, and optimize the performance of multibody systems.
Learn how to access and download required model files.
In this tutorial, you will learn how to create a pendulum model using Model Definition Language (MDL), run a dynamic simulation of the model, plot the rotation of the pendulum and view the animation.
In this tutorial, you will learn how to create a definition-based entity (such as a system) using MDL.
In this tutorial, you will learn how to create an analysis definition and instantiate it in an MDL file.
In this tutorial, you will learn to create a dataset to specify the start time, mid time, end time, and the force magnitude, include dataset definition in the analysis definition, and vary the magnitude and time of the impulse torque.
In this tutorial you will learn how to create systems using the MotionView graphic user interface, export a system definition to a file, and instantiate a saved definition in a model.
MotionSolve is a system level, multibody solver that is based on the principles of mechanics.
This manual provides a detailed list and usage information regarding command statements, model statements, functions and the Subroutine Interface available in MotionSolve.
