2024
This manual provides a detailed list and usage information regarding command statements, model statements, functions and the Subroutine Interface available in MotionSolve.
View new features for MotionSolve 2024.
MotionSolve® is an integrated solution to analyze, evaluate, and optimize the performance of multibody systems.
Discover MotionSolve functionality with interactive tutorials.
MotionSolve is a system level, multibody solver that is based on the principles of mechanics.
Geometric Properties ElementPABUSH lets you specify the bushing properties for an associated bushing element.
Geometric Properties ElementPBEAM9 lets you specify the geometric properties for an associated beam element of an arbitrary cross-section using a polynomial expression
Geometric Properties ElementPBEAMA lets you specify the geometric properties for an associated beam element of an arbitrary cross-section
Geometric Properties ElementPBEAMC lets you specify the geometric properties for an associated beam element of a circular cross section
Geometric Properties ElementPBEAML lets you specify the geometric properties for an associated beam element of a specific cross section type.
Geometric Properties ElementPCABLE lets you specify the geometric properties for an associated cable element.
Geometric Properties ElementPLINE lets you specify the properties for an associated line spring element
