PTSF
Model ElementDefines a point-to-surface constraint element.
PTSF/1, I=30103030, JFLOAT=30103032, RM=30102010, SURFACE = 555Format
PTSF/id, I = id, JFLOAT = id, SURFACE = id, RM = id
[, DISP = x, y, z [,ICM=id] ]Arguments
- ID
- ID of the curve.
- I
- ID of the marker whose origin is constrained to lie on the surface.
- ICM
- ID of the marker used as reference for defining DISP.
- ID
- Element identification number (integer>0).
- JFLOAT
- ID of the J floating marker on the body containing the surface. It is always positioned at point of contact and oriented such that the z-axis is normal to the surface.
- RM
- ID of the marker used to define the surface. This marker is fixed on the body containing the surface.
- SURFACE
- ID of the surface.
