2024
This manual presents solved verification models including NAFEMS problems.
View new features for OptiStruct 2024.
OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
Discover OptiStruct functionality with interactive tutorials.
This manual provides detailed information regarding the features, functionality, and simulation methods available in OptiStruct.
This manual provides a detailed list and usage information regarding input entries, output entries, and parameters available in OptiStruct.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides you with examples of the real-world applications and capabilities of OptiStruct.
Examines the hyperelastic behavior of a hexahedral element under enforced displacement using different material models such as Arruda Boyce, reduced polynomial, Yeoh and Ogden model.
In this problem, a rubber disk pinned at its circumferential edge is subjected to pressure load. This causes the disk to bulge into a spherical shape, like a balloon.
The combination of hyperelastic material models with viscoelasticity allows you to model the strain rate dependent large strain response.
Chaboche model, which is the extension of Frederick–Armstrong model, is commonly used in modeling uniaxial and multiaxial ratcheting.
Knowledge of the material model and its parameters is essential to predict the behavior of the printed components for FEM Analysis. Anand is one of the material models used to study viscoplastic materials.
This section provides quick responses to typical and frequently asked questions regarding OptiStruct.
