DENSITY
I/O Options and Subcase Information Entry The DENSITY command can be used in the I/O Options section to request density output for a topology optimization.
DENSITY (format_list, type, topo, peakoutput) = option
Argument | Options | Description |
format | <HM, H3D, OPTI, OP2, blank> |
type | <ALL, DES> Default = DES |
topo | <TOPO> No default |
peakoutput | <PEAKOUT> Default = Blank |
option | <YES, ALL,
NO, NONE,
SID> Default = YES |
- When the DENSITY command is not present, density results are output.
- Density results are only available for topology optimizations.
- Outputting the density results in all simulations allows analysis results to be plotted on the density iso-surface in HyperView.
- The frequency of this output is controlled by the DESIGN keyword on an OUTPUT definition or, if no OUTPUT definition exists with the DESIGN keyword, by the DENSRES I/O Option.
- Multiple formats are allowed on the same entry; these should be comma separated. If a format is not specified, this output control applies to all formats defined by the OUTPUT command, for which the result is available.
- Density results are reported as element strain energy in the .op2 file.
- Multiple instances of this card are allowed. If instances are conflicting, the last instance dominates.
