.dis.# file
The .dis.# file is a Patran 2.5 ASCII format results file.
File Creation
This file is created when the Patran format is chosen and shape or topography design variables are present. (See documentation for the I/O Option OUTPUT).
File Contents
| Result | Description |
| Shape | Shape results from
topography or shape optimizations. Output is controlled by the I/O Option DENSRES. |
- One such file is created for each iteration where the I/O Option DENSRES requests topography or shape results to be output.
- The # in the file name is the iteration number.
