_mbd.mrf file
The _mbd.mrf file is a Multibody Results File.
File Creation
This file is created when a multibody dynamics subcase is defined. The file contains time history data that can be used for 2D plotting in HyperGraph. Some data is written by default, and some needs to be requested.
File Contents
Data output by default.
| Type | Component | Description |
| Rigid Body | X, Y, Z | Position |
| E0, E1, E2, E3 | Orientation in Euler parameters. | |
| VM, VX, VY, VZ | Magnitude and X, Y, Z components of velocity. | |
| WM, WX, WY, WZ | Magnitude and X, Y, Z components of angular velocity. | |
| ACCM, ACCX, ACCY, ACCZ | Magnitude and X, Y, X components of acceleration. | |
| WDTM, WDTX, WDTY, WDTZ | Magnitude and X, Y, Z components of angular acceleration. | |
| KE | Kinetic energy | |
| Flex Body | All Rigid Body results | |
| Q/i, i = 1,2,...,n | Modal participation factors. | |
| XD/i, i=1,2,...,N | Modal velocity | |
| System | KE | Kinetic energy |
| CPU Usage | Total CPU time used. | |
| CPU/Sim. Time Ratio | The ration between the total CPU time used and the simulation time. | |
| Stepsize | Actual step size used in the integration. | |
| Integration Order | Order of the integrator used in the integration. |
Data output by request. The request needs to be defined through a REQUEST I/O statement.
| Marker Displacement | DM, DX, DY, DZ | Magnitude and X, Y, Z components of displacement. |
| Marker Velocity | VM, VX, VY, VZ | Magnitude and X, Y, Z components of velocity. |
| Marker Acceleration | ACCM, ACCX, ACCY, ACCZ | Magnitude and X, Y, Z components of acceleration. |
| Marker Force | FM, FX, FY, FZ | Magnitude and X, Y, Z components of force. |
| TM, TX, TY, TZ | Magnitude and X, Y, Z components of torque. | |
| Expressions | F1, F2,..., F8 | Vectors containing evaluated expressions. |
