OS-T: 1610 Thermal Fluid-Structure Interaction Analysis on a
Manifold
The purpose of this tutorial is to demonstrate how to carry out a Thermal
Fluid-Structure Interaction analysis on an engine exhaust manifold with conjugate heat
transfer and structural deformation.
Before you begin, copy the file(s) used in this tutorial to your
working directory.
This example is an engine exhaust manifold with conjugate heat transfer and
structural deformation. The structure is gray cast iron, initially at 300 K. The
manifold outer surface has a convective heat transfer coefficient of h = 6
W/m2 K at 300 K. The four inlets to the manifold are held at 500 K
with air as the fluid at 5 m/s. AcuSolve passes heat
fluxes to OptiStruct. OptiStruct passes the temperatures to AcuSolve.
Note: This tutorial is limited to study fluid and
thermal domain only.
The AcuSolve Fluid model
(FSI_AS_MANIFOLD.inp) and OptiStruct Structural beam model
(FSI_OS_MANIFOLD.hm) files are in the
TFSI_models.zip file. Refer to Access the Model Files.Figure 1. Fluid Structural Model
Launch HyperMesh and Set the OptiStruct User Profile
Launch HyperMesh.
The User Profile dialog opens.
Select OptiStruct and click
OK.
This loads the user profile. It includes the appropriate template, macro
menu, and import reader, paring down the functionality of HyperMesh to what is relevant for generating models for
OptiStruct.
Import the Model
Click File > Import > Solver Deck.
An Import tab is added to your tab menu.
For the File type, select OptiStruct.
Select the Files icon .
A Select OptiStruct file browser
opens.
Select the FSI_OS_MANIFOLD.hm file you saved
to your working directory.
Click Open.
Click Import, then click Close to
close the Import tab.
Set Up the Model
Create Set Segment
In the Model Browser, right-click and select Create > Set Segment from the context menu.
For Name, enter FSI_Interaction_Surf.
Click Color and select a color from the color
palette.
For Card Image, select SURF from the drop-down
menu.
Click on the Elements option and pick all the internal
faces.
Tip: To pick all the elements in the internal face, use the brake
angle of 30 degrees.
Click add to add the faces to the set segments.
Click return to exit from this panel.
Define Fluid-Structure Interaction Parameters
In the Model Browser, right-click and select Create > Load Collector.
A default load collector template displays in the Entity Editor.
For Name, enter FSI100.
Click Color and
select a color from the color palette.
For Card Image, select FSI from the drop-down
menu.
Under ELSET, for SURFID, select
See NLPARM Bulk Data Entry for more information.Figure 3.
Define Output Control Parameters
From the Analysis page, select control cards.
Click GLOBAL_OUTPUT_REQUEST.
For THERMAL and FLUX, set Option to Yes.
Click return twice to go to the main menu.
Create Transient Heat Transfer Analysis Subcase
In the Model Browser, right-click and select Create > Load Step from the context menu.
For Name, enter TFSI.
Click Color and
For Analysis type, select Heat Transfer
(transient).
Input/Select the Load Collector.
Figure 4.
Submit the Job
From the Analysis page, click the OptiStruct
panel.
Figure 5. Accessing the OptiStruct Panel
Click save as.
In the Save As dialog, specify location to write the
OptiStruct model file and enter
FSI_OS_MANIFOLD for filename.
For OptiStruct input decks,
.fem is the recommended extension.
Click Save.
The input file field displays the filename and location specified in the
Save As dialog.
Set the export options toggle to all.
Set the run options toggle to analysis.
Set the memory options toggle to memory default.
Click OptiStruct to launch
the OptiStruct job.
If the job is successful, new results files
should be in the directory where the FSI_OS_MANIFOLD.fem was written. The FSI_OS_MANIFOLD.out file is a good place to look for error messages that could help
debug the input deck if any errors are present.
Submit the AcuSolve Job
Open the AcuSolve input file (FSI_AS_MANIFOLD.inp) in a
text editor.
Change the socket_host
parameter in the EXTERNAL_CODE block to your machines hostname and save the
file.
Figure 6.
Open the AcuSolve Cmd Prompt application.
Enter the folder location for the .inp file.
Enter the command: acuRun -pb FSI_AS_MANIFOLD -np 8.
Note: Use the command: <cd <file location> And press
Enter to navigate to the respective folder.
Figure 7.
If the job is successful, you will see new
results files in the directory where HyperMeshwas invoked. The
FSI_OS_MANIFOLD.out file is where you will find
error messages that will help you debug your input
deck, if any errors are present.
The default
files that will be written to your directory
are:
cci.txt
Contains information pertaining to model
progression. Logs regarding connection
establishment, initial external code handshake and
subsequent time step data in conjunction with
exchange/stagger.
FSI_OS_MANIFOLD.html
HTML report of
the analysis, giving a summary of the problem formulation and the analysis
results.
FSI_OS_MANIFOLD.out
ASCII based
output file of the model check run before the simulation begins and gives some basic
information on the results of the run.
FSI_OS_MANIFOLD.stat
Summary of analysis process, providing CPU
information for each step during the process.
FSI_OS_MANIFOLD.h3d
HyperView
compressed binary results file.
View the Results
Using HyperView, plot the Element Fluxes (Mag) at
100 s.
