2024
Discover OptiStruct functionality with interactive tutorials.
Video tutorials using SimLab.
View new features for OptiStruct 2024.
OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
Tutorials using Classic HyperMesh.
Tutorials using HyperMesh.
This tutorial demonstrates the creation of finite elements on a given CAD geometry of a rubber ring.
This tutorial demonstrates the creation of finite elements on a given CAD geometry of a brake assembly.
This tutorial demonstrates the creation of finite elements on a given CAD geometry of a universal joint.
This tutorial demonstrates how to solve a modal frequency response analysis for a Differential housing model by including the effect of pretension of bolts as preload.
This tutorial demonstrates how to solve a linear static analysis for Bracket model and how to optimize the rib shape of the bracket using Free shape optimization analysis.
In this tutorial, a plate with a hole is analysed.
This manual provides detailed information regarding the features, functionality, and simulation methods available in OptiStruct.
This manual provides a detailed list and usage information regarding input entries, output entries, and parameters available in OptiStruct.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides you with examples of the real-world applications and capabilities of OptiStruct.
This manual presents solved verification models including NAFEMS problems.
This section provides quick responses to typical and frequently asked questions regarding OptiStruct.
